Opening Oceanstreamz 3.5.13 yields a splash screen to update to 3.5.14. I can download the update but it won’t install. The current version will not run - it simply keeps asking me to upgrade. The only Downloader code I have (9301333) is for 3.5.13. Deleting and reinstalling takes me to the same place. Has anyone had success updating? Thanks in advance!
Morning @wjschulz,
I’m experiencing the same problem. I just say later. It plays properly on my ONN 4K box, but it constantly crashes on my 4k Max. I was hoping the update that won’t install would fix that problem. Hoping the someone will notify the developers.
I always have the same problem, sometimes turning off my VPN allows it to install
