I just downloaded OceanStreamz site. It seems to be working well; except I cannot get subtitles. I went to settings section but cannot find anything related to subtitles/closed captions.
I don’t have OceanStreamz but I do see new releases are available so make sur youhave the latest one. Here is what I found on their site:
Yes, Ocean Streamz supports subtitles for a vast array of movies and TV series. You can easily enable subtitles in the video’s playback settings, allowing you to choose from a selection of languages when available.
Iam trying to get subtitles. I have language set to English. When a film comes up there is no way to find subtitle icon to click onto.
I am not sure what is meant by by playback setting?
Usually when you start playing a movie then hit pause or enter on your remote it will activate a footer bar at the bottom of your screen that is the playback settings.
This site only shows back - play- forward when paused. No other info on footer.
Sorry I don’t understand. OceanStreamz is an app that you install on your streaming device. You don’t use a Web Browser and go to a site.
Miki
My apology. I did install OceanStreamz and played a movie.
Movie plays fine, but when I pause footer does not have any symbol to get subtitles.
As they say “if one is available”. I might suggest getting a better app like Kodi or Stremio where you can use addons to get the subtitles. Sorry but I don’t have any answers for you.
I just tried to load this apk on my ONN Pro…I was able to download it ok but when I open it, it comes back with “update”…when you click on the update, it looks like it is downloading the update but then kicks back to the home page showing the icon. When I click on it again, it goes back to the same msg about an update…I could never get past this to test the apk…I will just delete the app
Ok. Not sure why that may have happened.
I don’t get many RD links in movies . Only getting 4 or 5 links per movie so for .
I use Oceanstreamz all the time and have not been able to find subtitles for every streaming link. However, for the ones that do have it, it is usually located at the bottom left of the screen. Move the pointer and the menu will pop up. It will be listed as CC or might be in the submenu of the gear icon. I hope that helps.
I used Oceansteamz on Firestick and like the site. When I got the new ONN box and downloaded oceansteamz it would not play. As mentioned I also was getting the update notice but it would never finish, it would just kick me out to the ONN home page. On firestick I was able to update Oceansteamz and it plays well. So must be something with the ONN box that is not compatible with Oceansteamz.
