Found another way to move obb to external USB on firestick, install TaiChi, install XInternalSD, ignore bug… Install your app using TaiChi installer, setup XInternalSD module inside TaiChi, use ex file explorer to move obb to external obb folder, open XInternalSD, enable for apps, select apps, back to launcher then open app… Working on gta3, vice City, San andreas with cleo and max draw distance. Troypoint app, rapid streamz, epsxe, happychick, unlinked and cpu-z so far no problems… Couldn’t get it working on asphalt 8 which would be great because its Huge for a basic 2021 firestick. (or any really!) If anyone knows how to get it on a usb I would appreciate your input!
