Oath Kodi Addon on Firestick
Can you install the Oath and use it right now on firestick Kodi
Oath no longer supported, New version called The Promise
Thank you! I have Oath already and it works but my brother wanted it . He just added The Promise…working great! Do you think I should replace Oath with the Promise?? or leave it alone?
Pretty soon the Oath will quit so I would just switch. Almost Identical
Thanks…will do as you suggest!
Yes, use other kodi addons. Its slim pickings without real debrid. But keep trying.
Thanks for input! I have real debrid.
