I am having a problem the nvidia shield pro and I just bought. I am switching from firestick’s and TV’s. I just set up the nvidia and I also have real debrid. I loaded the crew. I am switching because I thought it was a Fire issue.
I just noticed I do not get any of the free threads and I am not getting any working threads. Help please? Thanks in advance for your time and any assistance you can give.
Jayson
Follow the guides and use the search this has been asked alot. Re authorize your rd… you need to set it uo as if your new again.
I have went through MANY of the post. I bought the nvidia shield pro so it is a fresh set up and I also went online to real debrid and verified my account is still active and I deleted every device in it before setting up the nvidia, so I guess I have the 1 out of 10.
Like I stated if I don’t have any white links I have no available streams. I also noticed in the search I am not getting any free links just paid,
Well free links dont come as often. If your real debrid is up-to-date and isnt down. And you re authorized it then im not sure. Something tells me you didnt set it up correctly. Make sure you have authorized is correctly in the url resolver and make sure real debrid is turned on in settings. There is a step here you missed. And if you search url resolver there is instructions. There is a whole kodi mega list as well and instructions posted all over. Not trying to be rude but these are common steps people miss during the setup process. One little mispell or mistake messes it up.
Thank you. You also just gave me more information to narrow the search. Sorry new to asking or speaking in this forum, I am not trying to be rude.
Not at all, but as these are common issues i always refer to our search and the guides frist becuase 9 times out of 10 its been posted.
It was in real debrid. Since I have several devices here and a device in Panama, it has to be two separate accounts since they are two different IP addresses. So I have it working now.
