Nvidia Shield Pro External Thumb Drive
Did you have an issue with Tivimate after the update?
No issues with TiviMate but I have it stored in my internal storage not USB
Yep, but I now got the storing of backups and recordings all sorted out until Tivimate, Nvidia, or Android11 figure out their issues. I did a bit of a work around, but it works. just had to do a couple of extra steps.
MEMO!!! You’re the best!!! Did exactly what you said and it worked perfectly! I have Tivimate on my thumb drive and even that came back as if nothing happened. Thank you, thank you, thank you!
