Nvidia Shield low storage issue
After the real debrid issue yesterday I went ahead and added Premiumize to my Syncler account. When I started having buffering issues I decided to try the download links and end up downloading an entire series.
Now I’m getting a low storage notification. I’ve tried cleaning it up and I deleted the downloads… at least I thought I did.
It seems that I was successful in deleting the downloads because Syncler is only showing 294 MB of storage used.
Internal shared storage shows 4 GB of photos and video and I can’t find where they’re at and I don’t know how to delete them.
Try going to your apps section. There should be an app called Photos and Videos. See if that helps.
I don’t have any on my Nvidia so I couldnt open the app. But that may be where yours are.
Good luck.
I use X-plore to view the files and delete what I don’t want or need.
Already tried locating Photos and Videos in the App area… Not there.
File Explorer did the trick…
Thank you
Good morning I recorded two programs for the first time from an iptv and I noticed my Nvidia Shield was critically low on storage. I went back to the iptv and hit the delete icon and the iptv stopped working. I attempted to reinstall the iptv and the same critically low storage message keeps appearing. I deleted some programs but no improvement. Any ideas?…. Thanks!
Unless you bought the 500 gb version instead of the 16gb of internal memory version, internal memory capacity will always be an issue with Nvidia Shield, especially with downloading additional apps on top of the proprietary apps you can’t get rid of. If you like recording and downloading media, consider getting an Android TV device with at least 64 gbs or more of internal memory.
I added a 256GB ssd to my shield Pro, and formatted it 20/80. So 20% for apps (internal) and 80% for recording (External).
