Nvidia ethernet not connected
Hi is anyone getting the above message on there nvidia pro.it does not effect my viewing just annoying flashing on my screen sporadically only just started to get this message since there was a problem with V***gin media outage. anyone solve the issue
Regards
Sqonk40
Nope, not on mine. Try unplugging for about 10 minutes to let the unit cool down and then restart.
Hi
Thanks for the reply will try what you suggested.
Regards
Squonk40
