nVidea shield 2017
Cannot download apks from unlinked sites. They all fail
@bobsal90
Thank you!
I have tried others and I still can’t it to install, it keeps failing.
I got it download but it wouldn’t install.
I was trying to install cinema and others as well.
@bobsal90
Not a problem.
Mhmm try turning off play protect
When that happens that they download but won’t install. I immediately go look in X-plore in the Download file. They are usually there. Then I just install from there using the package installer.
Thanks,
I tried, but it was not there.
How to do you turn off play protect?
@bobsal90
Try what powerfader suggested.
I think the new nvidia update may have screwed this up but try it. Try getting these from apk pure, or put them on your phone and send them to your shield.
Thanks everyone. My fault, I had to uninstall Cinema before trying to get the new version.
