Is it necessary to have Real-Debrid in order to successfully use Syncler. I was using Syncler without Real-Debrid with no problems for several months and then a coupe of months ago it indicated that it couldn’t find any links and this has problem persisted up to now even when I re-installed Syncler. I even used the version on the Troypoint app with the auto-installer. The result was that Syncler then told me that I don’t have any services installed.
Make sure your real debrid is up-to-date. Re authorize your account on the app/apk you are using Delete your devices in real-debrids website and re add them Make sure they are added in real debrid.
