Not gettin audio from mx player or vlc player
not getting audio from mx player or vlc player on weyd or cinema hd. Only get audio with internal player
i use mx and vlc not getting any problems
Make sure your decoder is set to HW+
Make sure your audio is enabled on your player of choice.
tried all suggestions-still no audio. works fine with internal player. Tried with onn box and firestick-same with both.
Well, I guess you could learn to read lips? lol
Sounds like you may be missing a codec, or a codec is corrupted in your internal player or external. Try uninstalling your vlc and MX Pro and reinstall.
Also, if you reinstall vlc and MX pro download from a different source than what you did originally.
Just had a look and on my 4k onn box with Exo player there is sound for weyd, I would use the internal player.
