I have downloaded Twilight through Kodi on my fire stick with the coco add on and when i go to twilight and try to stream a movie all I get is in the top right had corner of my screen is “ no debrid providers enabled then no results.
Can you help me resolve this.
Thanks
I’m not familiar with a coco addon but some Addons are debrid only. Meaning if you don’t have a premium debrid service (like Real Debrid) you can’t use the addon. In general it’s a good practice to have a debrid service using KODI as you will be hard pressed to find playable streams without one
try onstream works well no debrid needed
Thank you for your response, I’m a bit new to all this, how do I get my downloaded twilight to work as it doesn’t seem to be able to stream movies!
use downloader type in onstream.so
Okay I did not know what Twilight was but now realize it’s a FEN Fork sort of. I found this from troy. I’ve been using KODI for more than 6 years and IMO this is waaaayyyy to much work for an Addon especially if you are not an advanced user. I recommend you install other addons that are working perfectly like The Crew or 9Lives. BUT you will need Real Debrid. and if you insist on using Twilight you MUST get a premium Debrid services as pointed out in Troy’s article:
“As noted above, it appears to be a fork of the FEN Kodi Addon and works in the same fashion. Users must integrate an unrestricted downloader such as real-debrid, AllDebrid, or Premiumize. In this instance, we will authorize real-debrid which is the most popular unrestricted downloading service.”
