now that nord has bought surfshark is there a difference? my nord is expiring soon. should i switch to surfshark?
For one Surfshark gives you unlimited devices where Surfshark only 6. Also you will be getting the cheap introductory price for Surfshark.
Also, Surfshark provides a working kill switch on Firestick/Android TV whereas the last time I used Nord, they didn’t. Nord’s Fire TV/Android TV app doesn’t come close to the capabilities of Surfshark from what I can remember when reviewing. BTW, thanks for being a Patron!!
Nord now has a kill switch -
Does it function on AndroidTV though? That seems to be the drawback of mostly all VPNs.
No killswitch on a 4K Max that I programmed 2 weeks ago, but Nord may have an update/fix since then. I’ll fire it up and see.
Yes, most VPNs have a kill switch for their Windows/Mac apps but not on Firestick / Android TV. There is some “secret sauce” that Surfshark is using that the others don’t know.
