I tried using MX Player w BeeTV instead of its default player and no option with a list of subtitles shows up. Any solution to get subtitles using MX Player?
If MX is open and playing the video, one of the icons at top right should open to show you the menu for subtitles.
Indeed it does but only options are searching for it on the web through “opensubtitles” . Impossible to guess correct keywords or file name. Any suggestions, most welcome!
2 minutes later and I answered my own question by finding this tutorial:
I will try tomorrow and sorry to take your time!
I encountered the same problem. What benefit does MX have over default player?
