Looking for some assistance from this great team of streamers. I wanted to try out the new Cinema version 3 so I deleted 2.4 and loaded the correct version 3. I added MX Player Pro and selected as the default player however I don’t get any sound. The Cinema player works however I would prefer the MX player. Any suggestions are greatly appreciated.
In MX player setting under audio codecs think the 4 boxes at top need to all be checked to on. Something in that nature. Its been years using that for me.
I have to use hw+ decoder. You could try different ones. If you’re watching something, push ok to open on screen menu. Up in right corner.
Try VLC Media player free from playstore…worked for me
Thanks
found boxes unchecked
