I updated Xenon to version 8.3 and it got rid of my TV Guide (PVR). I get the no PVR add-on enabled message. HELP!!! Newbie here trying to learn.
Still many issues with Xenon 8.3. You have to go through the. Skin settings> Player settings you will find it there.
Many users have issues with this version. The best thing to do is to downgrade to the latest stable version, otherwise you will continue to have other issues as well.
Here is TP manual how to setup Xenon build. If you scroll down to table of contents then go through the settings.
Thank you for the info. I was actually able to find and activate it and its working now. If I continue to have other issues I will downgrade. Thanks again.
