No playable sources found for item
Kodi not working….nothing but blackscreen
@JediJudy
Re authorize your account
Delete your devices in real debird and re add them
Do you have a real debird? Also what addon? What device? What app?
RD up to date
Firestick 4k
I only have Seren on kodi 19.3
Then follow the steps above. Re authorize.
Try the oath or fen or the crew. Seren stopped working for me. But the aforementioned 3 items work fine.
Good luck.
Kodi occasionally gives me a black screen when I try to open it. I am not using a Firestick; I am using an Android TV box. When it happens to me, I go to apps (or manage apps) and Force Stop Kodi. Then I re-open Kodi and it always works. I also do not use Seren. I use The Crew, The Oath, and Marauder.
