Having an issue getting a picture with some links, get voice but no picture. Have VLC media installed. Any other suggestions would be appreciated,
My only thought is that you may not have hardware exceleration active.
From the menu toolbar select Tools → Preferences → Input & Codecs → Codecs → Hardware-accelerated decoding. To disable, select Disable. To re-enable, select Automatic (unless a particular hardware acceleration method is desired).
Remember to press Save to save VLC settings and restart VLC after that to make sure changes are enabled.
