Hi all, for 2 days now I am not getting any server lists when trying to open favorites or even searching (crew, homeland, etc.). When searching I get a blank result - real debrid is up to date. I’ve tried on 2 different builds (xenon and superman) and they both react the same. Just wondering if the community is having any issues. Thanks
I don’t use builds myself anymore. I use a couple addons in Kodi. I use The Promise, The Crew, And Moria. I have had no problems at all with watching anything I choose with Real Debrid. Maybe try dumping the builds and just trying a couple addons instead.
Did you try Resolve URL? Re Authorising Real Debrid usually is the problem
The problem is not Builds. Perhaps you are just using the wrong Builds. I’ve been using Builds for more than 5 years. You just need to find a good Dev group that maintains the Build
I used builds for many years also. Once I realized that the build devs do not maintain the individual add-ons, I stopped using them. The builds are at the mercy of whoever is supposed to maintain the individual add-ons. I have an IPTV service I use for all my sports and live programming. I just use Kodi for movies and tv series. The majority of the time when I had builds, I mainly only used one or two add-ons. So, I dumped the builds and just use add-ons with Real-Debrid. Plus, I save a bunch of space on my device. To each his own. Whatever works for each individual is what you should do. I will agree that a lot of builds are garbage and not maintained, or are great at first, and then slowly deteriorate over time into a not user-friendly mess. So, I just stopped using them.
Agreed, but the Good dev’s will quickly throw out the broken/no longer maintained Addons and replace with working Addons. In all my time using KODI (At least 6-7 years) I cannot recall a time when there wasn’t at least 2-3 good working Addons. The Dev for the build Group I use has always kept his builds well maintained with working Addons
Another option that’s not discussed much is make your own build. Then it’s exactly what you want and you never have to worry about a developer making changes.
Yes did that - thanks
Most people won’t take that long to learn how to do it lol. I made a build and shared it then quickly deleted half the stuff I did on my own device lol
Dug out my other shield with green monster installed and it works. I think I will do one box with just a few addons and try that too. Thanks for all the suggestions. I was just wondering if anyone else with the above builds have any issues.
