Why isn’t this build available on K19? It’s highly rated. Is it worth downloading on 18? TIA
That question should be asked by the devs who maintain it.
Nothing we can do, if you want to use that build use kodi 18. You can use a fork. I suggest sticking to 19 but thats me.
When the code changed some devs didnt update their builds.
Understood, thanks. I was just curious why a top-ranked build wouldn’t be supported any longer by the devs. I’m using my own build on K 19, but wondering if a supported build might be easier, like Crew Green Monster or Transcendent?
