No IP lock, multi-device Playlist & EPG editor
No 100% sure if this is where is should ask, but felt most appropriate.
As the title says, can anyone recommend a IPTV Playlist and EPG Editor that I can use across multiple (4) houses? Open to free or paid options.
Trial would be great if paid
EDIT - if IP locked, multiple devices within 1 household is fine. Maybe that would even be preferred? Anyways, obviously open to option. A good IPTV player with device syncing that has a built-in editor - although that would be more time consuming obviously
Tia
I can only recommend the one that I have used and its
Another popular one is IPTVBoss. I know there will be more suggestions so hang tight.
$24 CDN for a year is pretty good.
Which site/app?
Not sure what you mean. If you are referring to the post by @Masterofmydomain then click on it and have a look.
Gotcha. They mentioned a few options. Linked to one. I’ll go check
