No Audio on Stremio
Is anyone having audio issues with Stemio? I am finding a number of the feeds play like they are muted, it’s not, but cannot resolve, I have to search and often run lower res to get audio. Any ideas? Thanks, Jim
What device are you using it on? Have you checked your devices audio settings? I don’t have any issues with Stremio.
If memory serves me correctly Stremio uses it’s own internal video player that sometimes doesn’t have the kodecs you need to play some vids. You can however change in setting & use a external video player which I believe Troy showed in his video. Sometimes some external video players also don’t play nice though. I can’t remember if it was VLC or Just that doesn’t. Also make sure you have the latest updates on your video players. New kodecs come out all the time. :crossed_fingers:Rick
Force stop the app and or reboot the box, not just restart from the systems menu, unplug it for a few minutes and allow it to fire back up, while you are at it it would be a good time to do your router also. Just make sure the router is back up and running before plugging in the TB device.
I’ll give that a shot, thanks
ONN 4K Pro
