Hi:
I just purchased a Nividia Shield Pro and I’m wondering how to expand external storage. I want to format the USB to half storage for apps and half for external storage for recording. The only option I see on the Shield is format to complete device storage for apps. I have watched and used Troy’s RDB Shell video for extra storage on my Firestick 4K and this worked well. Can I use this on the Nividia Shield Pro? Thanks.
You can use your pc to divide the usb say one for fat32(use with shield) and one for storage. Im on linux so to do in windows im not so sure but it should be simple.
https://results.dogpile.com/search/web?q=how+to+divide+usb+stick+for+use
