I was just wondering if there is any setting that I need to change in order to watch NFL games on Kodi without constant freezing. I try almost every stream available under the NFL tab with the same results.
I have version 19.4 on the Firestick using the Crew. Speed test shows 65mbs down and 30mbs up while connected with IP Vanish. Any help would be greatly appreciated. Thank you.
Try using Real-Debrid. Should eliminate freezing (buffering).
I was wondering if that was going to be my answer. Thank you, I will definitely try this.
Real Debrid isn’t a factor in live streaming.
For smoother, more dependable streaming of live sports, you’ll need a paid verified or unverified IPTV service.
Freezing is a constant battle for cord cutters and involves MANY reasons why this could be happening. There are tons of articles to help, but my advice is to get a paid IPTV service instead of trusting Kodi to run perfectly. It could be a hardware issue, it could be a software issue, it could be a security issue, but mostly I would get used to using Kodi as more of a backup plan, as all services seem to come and go. RD may help with some of it (not live streaming though), let us know if it gets any better!
Thank you everyone for your help. Is there a specific streaming service that you recommend?
Try this…
This is a ongoing discussion regarding kodi and live streams of anything really. Use the search and also go to troypoint.com and look at sports streaming. You will also need to look at an iptv provider, which troy has a list up on his site.
Cant name them here, thats what the main website is for.
I have tried just about all of the streaming sites from Troy,
Using Silk browser.
I can’t get a single one to play, they all seem to go to sports betting pop-ups the won’t go away.
I don’t use Kodi or Real-Debrid.
Any suggestions?
thanks
With the free sites you need to learn how to close the pop ups and which ones you need to accept. For example some sites need you to accept a redirect and you know that’s what you must do if at the end of the redirect window you see " SID= ". That’s a station ID. Don’t choose HD links as they always go to a “pay” site. The first couple of times it takes about 3 to 4 “close” or “Deny” clicks to get to the free feed. If you need more step by step then PM me and let me go through the steps with you.
