New Fire TV Bug Blocks Downloader and "Unknown Apps" Setting
The Fire TV Stick HD (2nd Generation), released in 2026, runs on Vega OS 1.1. This is a Linux-based operating system that replaced the traditional Android-based Fire OS found in previous generations.
I’m getting about the same thing on a BuzzTV X5 64/128 AX-C right after a OS update. I open Downloader and then closes. Also Troypoint APP is gone.
That worked. I disabled my VPN and was able to install SportzX.
Thanks Troy
I just received an ad from www.wirewireweb.net. They are selling jailbroken Firesticks, the same as I have for $79.99.
Are they for real! Are they worth it?
JAILBROKEN AMAZON FIRE TV STICK HD 4K MAX FULLY LOADED
Brand New Firestick 4K Max with Alexa Voice Remote and Kodi**
Our Fire TV Stick 4k Max has almost every movie and TV show ever made available.
You can find and watch almost any movie or TV show minutes after it is aired by its network.
Watch every movie, tv show, live sports, tv series, cartoons, and live tv with the click of a button instantly!
Cut the cord! No more cable bills or monthly fees EVER!
FEATURES
Unlimited Movies
Unlimited Movies in Theaters
Unlimited TV Shows
Unlimited Shows from Any Network
Unlimited Pay Per View
Unlimited Sports
Unlimited Live TV
And Much Much More!!!
No More Cable Bills or Monthly Fees Ever!!!
Latest Version of Kodi Installed *
Latest Version of Cinema HD Installed *
Latest Version of CyberFlix TV Installed *
Latest Version of SportsFire Installed *
Latest Version of LiveNetTV Installed *
Latest Version of TVMob Installed *
Every Movie & TV Show Ever Made At Your Fingertips
Kodi was configured to automatically update all addons and software so it always get latest addon updates
* We frequently update our setup to ensure that you have the latest and greatest, so the included apps may change
@jmaute not sure sounds a little steep and if it has all that how much of it is actually real? and what else may be loaded on the stick? just my opinion
I’m typically against these “Fully loaded” devices but that’s not actually a bad deal if you are really getting all that.
10 year KODI user but I have no idea how they auto update KODI though and keep in mind when a major new release (Not a point release) of KODI comes out you will need to reinstall KODI and any addons as the Dev’s typically tweak the addons for the release.
Also the APK’s come and go some will die. Some mentioned above already are dead (Cinema, Sportsfire)
As long as you are comfortable with Fixing things when they break (they will) and can add apps to replace the ones that die I don’t see any issue with you getting this
@SoloWarrior @jmaute Yes I get it but also isn’t the new Amazon firesticks with Vega OS? And isn’t Amazon blocking a lot of stuff? Just curious since I have 3 Firesticks and still using Version 8.1 Fire OS had applied the fix that was posted and while back and so far so good :smiley: but also have a 1st version ONN that is still in the box just everything has been good so far just hate to change LOL get him to the greek russell brand gif | WiffleGif
Yes I am aware and do know LOL
@DaleB1 I also thought about the Vega OS as well but am just assuming these are older Firesticks because as you said none of this would work on the new sticks with Vega OS.
I’ve been off the sticks for several years but still have a1st Generation one I take when I travel. KODI and my IPTV services work great on it
What’s a firestick?
1000014666
