Originally published at: New Fire TV Bug Blocks Downloader and "Unknown Apps" Setting
Fire TV users are reporting a new bug that is preventing Downloader and other applications from receiving permission to install apps from unknown sources. The issue was first discovered and reported by Elias Saba of AFTVNews, who found that some devices running the latest versions of Fire OS 7 and Fire OS 8 are no…
Am getting this same error on a recently purchased ONN 4K Plus device {16g|.
This is why I was trying to get away from the Fire Stick. Seems to be a failure now.
Get an error when attempting to download Stremio says it’s an unknown error and to check URL.
Seems the $$$ for the ONN and Surfshark have been wasted.
I’m having the same issue on the Onn 4k Plus and the Firestick. I hope Troy can help with this soon.
If using a VPN try disabling that temporarily and try again. Also, make sure you are using the proper Downloader app by AFTVNews.com. There are multiple Downloader apps in the app store that are scams.
Thanks for the suggestion. Wasted a lot of time and money today on this and I’ll try disabling the VPN tomorrow when I’m in a better frame of mind. Thanks again. {yes I made sure, based on your tutorial it was Downloader from AFTVNews.com}
Getting same error on my onn 4k
Have tried resetting and restarting to not avail. Help Troy or some one
Thanks Roger
Tried to download the Stremio app with VPN shut off but no joy. Same error msg. Does not seem to connect to the URL driven by the TroyPoint install icon.
Will wait until someone discovers a fix or just try Kodi although I’m too tired and too old to keep chasing Kodi’s monthly challenges.
Try rebooting your streaming device and router. If that doesn’t work, uninstall/reinstall Downloader. The links that we use for Stremio are the direct links for the official Stremio Website.
There is no doubt that this is a network issue on your side as it works for everyone else. Make sure that you don’t have some sort of ad blocker operating on your network as well.
You nailed it! Not the ONN but rebooting the Router fixed it. I keep it up to date with it’s firmware but it seems in the internet world we are always on the edge between success and failure. Thanks for your help. Now back to finishing up with your tutorial
I have used the fire stick for over 5 years. Last month I bought a new Fire TV Stick HD. I tried to jail break the stick, but first I cannot select “ADB debugging” from or APPs from unknown sources" from Developer Options.
SOFTWARE version: OS1.2(2101020054820)
UPC is840414612631 and DSN is GT542A0454930CJV..
Is there another way to jail break this firestick?
If this is the new Vega OS then you are locked into their architecture and can only add what they allow.
How can I find out if it is a Vega OS? I don’t see it anywhere.
@jmaute , this is an AI answer sooooo,
The new operating system for Amazon’s Fire TV Sticks is Vega OS, a Linux-based platform that replaces the previous Android-derived Fire OS.
Adoption: Vega OS is now standard for all new Fire TV Stick models, including the Fire TV Stick 4K Select and the 2026 Fire TV Stick HD.
Key Changes: The OS is designed to be lighter and more secure, running efficiently on 1GB of RAM, but it does not support sideloading third-party apps or APKs.
Developer Support: Applications are built using React Native and HTML5, restricting users to the official Amazon Appstore.
Legacy Devices: Existing Fire TV Sticks running Fire OS (such as the Fire TV Stick 4K Max and 4K Plus) will not receive an update to Vega OS and will continue using Fire OS 8 or 7.
@itzme been using 3 Firesticks as well as 1 TCL Fire TV all are on version 8. Did the fix to prevent updates and such that was post before all that started. been using them since then so far everything has been ok for now ![]()
@DaleB1 , I’ve not been a fire anything user for a long time, so you’re guess is as good as mine, thatz why my reply above was an AI response…
@itzme no worries just got so used to Firesticks and they were very easy to setup and use I do have a 1st Gen ONN just never got around to setting it up Thinking maybe now would be a good time to get familiar with something else. But not sure which way ONN is going with Google not big on change either and yeah I know if you don’t move forward with change you will get left behind or hit a brick wall LOL
Give that Onn device a try. I think you will find, as I did, it’s easy to setup. I still have two of them on my bedroom tv’s. Each of them work great.
@jmaute here is what my firestick shows and shows Fire OS yours is just showing OS so assume that is Vega but not sure I am also on an older version of the Fire OS
Device Name
8th Fire TV
Device Type
Amazon Fire TV Stick 4k Max (2nd Generation)
Storage Capacity
6.04 GB of 12.98 GB used
6.94 GB of 12.98 GB available
Amazon Account
mine
Software Version
Fire OS 8.1.4.9 (RS8149/3133)
Fire TV Home Version
7230131.1
Serial Number
G072JM0733370
Current Date and Time
Sep. 6, 2026 8:30:54 AM EST
