New error code with Cinema Hd
Anything that I try to stream on Cinema hd whether I choose Real-Debrid or not comes up with this error code:
Error
Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 1 path $
I can either select Setting or Close
I have restarted Cinema. Cleared the cache and also restarted my firestick and it is still happening. It was working fine yesterday.
Has anyone seen this before?
Any suggestions.
I’ve been dealing with the same problem. I did the same thing you did but nothing worked, so I uninstalled it and then reinstalled and so far I haven’t gotten that code. I’ve been ok now for about 3 hrs. Good luck
When you delete and reinstall, are all the favorites saved from the deleted version? My favorites are like my new Tivo playlist. A lot to resave if so. I just got this evil code as well.
It also may be related to real debrid being down, which I use, as per the next thread beneath this so might be fine tomorrow.
I doubt that it is due to Realdebrid being down because i got the same error when i chose non real debris links.
Thanks…. I am glad that i am not the only one experiencing this. If it doesn’t get corrected somehow i guess i will have to reinstall Cinema. What a pain.
I just started Cinema and it is working! I guess it was a glitch that they fixed. I really did t want to do an uninstall since we just did this when we upgraded our firestick. But I believe there is a way to back up your favorites list and reinstall. I have never done it but vowed to do it next time.
