Some shows on certain Networks will not find links to play.
It would be helpful if you say what app or addon you’re using and how it’s configured. Are you using Real Debrid or a similar multihoster?
I’m guessing he is talking about free Kodi IPTV. It would be nice to not have to guess though lol.
I use Kodi 20.1 with the Sumerman build i use Fen and Seren usually for my addons with Real Debrid. Most of the shows i watch play with no problems but there is some that come back no playable sources or no results.
I have found that too…sometimes I can get on Cinema but not often. Sometimes they show up and yes it’s frustrating when you’re in the middle of a season or a new season comes out.
I just take it in stride and am glad I’m not paying for cable to watch infomercials and garbage.
This is an unsolved mystery I’d love to get to the bottom of because honestly I’m tired of seeing the same question over and over again. No offense to either of you.
I’m hypothesizing that this has something to do with the way that some of these builds are set up. I haven’t had any of these issues and I’ve used FEN, Seren, Homelander, and The Crew. I’m not about to install the Superman build just to test out my theory and go digging through all the settings though.
Install a fork of Kodi and install one of these addons and make sure that Real Debrid is properly authorized. Do a search for the same shows and see if results vary. Then report back on what you find.
@JediJudy what are you using? Same build?
Hi Jay
No
I don’t use builds. I am currently using Kodi 20.0 with Seren and I use a very old version of Cinema. Both have current RD, use IPVanish
That’s it
FS 4K
I mostly watch European and Australian crime dramas. If that helps.
I look into the fork thingy
Thanks again Jayhawks
I’ve noticed that with The Crew, latest version that I can access the networks section and obtain links for shows on my streaming box upstairs but it doesn’t work on my Shield device in the living room.
Not sure why this is. Any thoughts from the Troypoint Tribe?
Thanks. Going to try uninstalling it and reinstalling it to see if that might fix the issue.
Cheers
Timelord ! Let post your results because I am also having trouble with The Crew addon in my Nvidia Shield Pro.
