Network Connection
Cant seem to install diggzrepo due to “network connection” issue. Not sure how to resolve as my internet connection is working fine
I have the same situation. States, possibly due to network not being connected. It is, with active VPN. Get identical results from 2 different android units
Adding further info.
Kodi fine.
Build is not.
I’m going to try the add on install again with the Surfshark off to see if that makes a difference.
Try the download with the VPN off? That has worked for me in the past.
I have the same problem with every time I try to add on to kodi.UNABLE TO CONNECT>COULDNT RETRIEVE DIRECTORY INFORMATION>Could be due to network not being connected which it is.HELP
https://diggz1.me/diggzrepo/
I am having the same issue. The diggzrepo installed but nothing else does…please help
I’ve had similar issues in the past. However when it talks about not being connected it is referring to the site of the app you are trying to get. I also discovered by waiting two or three days things were corrected on the other end and I was able to do my download and install.
