Netflix Secret Codes - 2024
Been trying out the newest secret codes listed by Troypoint (Netflix Secret Codes in June 2024 (Hidden Movies & Shows)) and found a few difficulties/inconsistencies. The search results seem to be complete when the code is run from a browser (i.e. - https://www.netflix.com/browse/genre/xxxxx). However, if you type in only the Code to the Search line for your Android TV OS Netflix installation, the results are very different and in fact do not line up with the genre very well. Also, a complete list of Genre Codes can be found at: https://www.netflix-codes.com/. Any help is much appreciated.
As a matter of fact, it almost seems that the Netflix App (installed on Android TV OS) does not recognize the secret code when typed in using the search engine (sometimes that “Error” message actually comes up) while it works correctly using the browser method.
Just to save everyone some time - did some more checking on the situation. In fact, the secret codes CANNOT be used in the Netflix App (in Android TV OS), only works using the browser method. In the Netflix App you are stuck with the predetermined Genre Categories listed under the Search Engine keyboard display. No way, that I can find, to even add new categories to this list. No Joy in Mudville Today. Thanks.
