Netflix on Kodi
Hi, Loving the Crew now. And I would love to stop paying Netflix, but I am hooked on the layout. How do I know what’s available on Netflix without scrolling thru every movie they have?
Thanks in advance, Rosie
I know they separate the Netflix TV shows on Crew from other sevices but I don’t see the same option for Movies (only D+).
There are kodi builds (Diggz Xenon is one) that have a “streaming sevices” menu that will offer that option for you in the Movie and TV show menus. But it doesn’t seperate studio films from Netflix Originals.
Hope this helps.
Yeah screw Netflix, now that you are cord cutting it’s not needed as you can get everything there. there are a few services that you can setup that will tell you when new movies/shows become available. I like Reelgood. Lot’s of customizations and it will even send you emails when your new show episodes become available
https://reelgood.com/
Don’t know nuttin’ about Kodi, but can you install Trakt?
There are a few builds and some add-ons that have menus that separate tv shows and movies by network so all the Netflix shows will be in a section and movies will have their section
i use the 19.3 diggz build in the unlinked 12341234 store with real debrid added it works quite well
Get a Free Reelgood account then you can connect the services you want (Netflix, Hulu, Prime, etc…) and it will tell you what new movies/shows are coming out on what day. You can also sync your Trakt Account and be notified when their is a new episode for one of your shows available
Really Good site to see what’s popular on Netflix in US and the world for both movies and series
Hey, thanks for the link! :laughing:
Yes, I think I have Trakt. I forgot about that. Thanks!
