I have a mecool m8s pro l. And I’m looking for a version of Netflix to use that’s not a mobile version. I tried the Kodi addon and everything installed. But I’m getting an error message about inputstream not installing.
If the box isnt netflix certified you wont get hd netflix, please do a search on this and when looking into boxes like mekool only some are netflix certified.
If netflix is something you wish take a look into certified netflix devixes, or smart tvs.
@TP-Dracoo I have a couple of mi boxes and a roku tv that i use. I bought the mecool box a few years ago and figured i could yse it when go out of town. It’s a good box other than not having certified Netflix. I used the modded one that uses to ve on the rapid installer. But it stopped working.
The rapid app is down. We have a toolbox now. Yea, you will have a hard time getting netflix to play properly on a non certified box.
