i joined Surfshark last night to access different countries to receive different Netflix content. It worked perfectly last night but it appears Netflix has caught on and i cannot do this anymore without disconnecting the power from the device and doing a reboot. Even this only works once and the process would have to be done again which is too much work and takes up too much time. I’ve cleared the cache and but this doesn’t work.
Have you tried another VPN like a free one just to test. And is it possible if your using on your router a DHCP to unplug power and then change passwords for your wifi then your surfshark and make sure you have updated app version. Just thinking of all possible steps. Hope this helps. I do not use Netflix but someone in a different region told me he had the same restricted content problem. I only know one way around this.
Troy I saw you release the video today about being able to connect to Netflix UK and watching the office. I’ve also been able to do something similar with the series demon Slayer for the kids. One thing that I keep having problems and haven’t found a solution maybe you could help is connecting to Arabic countries to watch their Netflix versus the US.
I wonder if the TDUK DNS Switcher with an encrypted DNS would help? Just a guess though, as I’ve never used netflix, and have it disabled, but maybe something to try.
It just depends on which country you’re trying to watch the from like I can watch certain shows from Japan and other countries. But certain countries like the Middle East I cannot.
