My T95Z plus freezes
I turn on my tv and my T95Z says BOOT,but nothing happens.I unplug the device still nothing happens.I see that there isn’t a reset button,to reset the unit.I hope its damaged in a way that have to buy another unit
I been looking on youtube and they say it might be the adaptor.I’ll try that and what happens.I’ll let you the results.
If your box gets too hot, it will freeze up. I’d suggest getting and using a usb fan underneath it if the components aren’t already cooked.
that’s not bad idea.I’ll try it.THX
