MX Player Pro Fail
I tried to download the MX Player Pro from the Rapid App Installer after uninstalling the standard MX Player. As it tries to install I get a message saying “App not installed”. Tried it several times and no joy. What am I doing wrong?
That message usually means that there is a previous version of the app already installed. Did your existing version definitely uninstall before downloading new one ?
@PaulC yes I did go back and check that to make sure it was gone. The other thing I was wondering if the file was too big for the available storage space. I have most stuff on an SD card but with the Amazon bloatware there isn’t much space there. I’ll try deleting a few things to see if that’s it.
Sounds like a good idea. Good luck !
I tried installing from Downloader and it seemed to go OK. I launched Cinema and went into settings to change from Cinema Player to MX Player. Went to a random streamer and hit play. Got a message saying “MX Player Not Installed”. Go to Manage Installed Applications and it is there. Shows as Version 1.30.6. Also MX Player shows as an App on my recents. I wasn’t sure it was supposed to show up as an app…
Not sure where to go next.
Troy?
Not sure if this is where I’m supposed to report this or to try to get help or if I need to make a new one since this is so old
Every time I try to install MX player No matter how I try to install it whether Downloader through you guys or another source I keep getting the message App Not Installed. I don’t already have a Mx player loaded
And I’ve even double checked I’ve refreshed restarted, then gone back in to try to download it several ways and it will not install
what device are you using
I got that error when my Wi Fi sped was low I tried it on ethernet and it was perfect.
welcome
Please be sure and answer any questions so that we can get an idea on where and how to help you.
Amazon fire cube I have the fastest WiFi and I have tried in every way possible but won’t install I would have replied yesterday but it wouldn’t let me
Have Amazon fire cube have the fastest WiFi and I have tried in every way possible but won’t install
have you tried installing an apk
Yes I have many Apk as well as kodi I’ve been cord free since 2017 not new to this And I had MX downloaded before, but when I got my new fire cube and stuff and I went to install it it’s just not it won’t install
only thing i can suggest is take fire cube back to factory settings and start from scratch
Follow the tutorial from Troy above ∆∆∆∆∆
Troy’s tutorial was the first tried I always follow Troy first didn’t work I tried several times
did you go into downloader settings and clear all files
Yes even though I always delete right after I install still checked
