Trying to put mx player on tea tv
You install it separately on your device then make it your video player in options after install.
Mx player is not offered in settings on tea tv when you enter a movie to be played or in the settings they offer the preferred player
Yes. You still have to install the apk of each player in your device, once you have done that you can set it to your choice of player.
I recommend mx player.
Thought they were already on this installer justhave to designate which movie sites I want to view by pushing install icon
They are on the installer and yes you can choose which one to use on the app.
Been trying to get cinema installed onto mx player have put in url https://cinemahdapkapp.com it says can’t play this link have 2nd generation firestick an ip vanish on what am i doing wrong
Sup Rampage…
I think u got it backwards
You download both apps, then you go int Cinema settings & make MX your player
It plays everything through MX
Ok but why on mx player does it ask for url
Oh it can play all sorts of media…
But Cinema, BeeTV, TeaTV, etc… all play through MX player without the hassle of entering anything
Ok thanks for clearing that up for me zorlac
Anytime…
Just go into each movie apps’ settings & change from default player to MX player…
Stay safe!
I don’t have an option on Bee TV for playing with a different player and it keeps recommending Titan player which keeps buffering. Any ideas?
Sup Yq…
I take it you already have MX already installed…
So go into BeeTV settings…
Go down to"Choose default play action"…
Choose “play with external player”…
Now go play a link & it’ll ask you which player & then choose “always”…
Happy Halloween…
Obviously, I’m missing something with TeaTV, as well. I have MX Player installed on my nVidia, but TeaTV only wants to have me install their player (which sucks). When I select a link to play, my only options are “Play” “Play with subtitles” and “Copy link”. I see nowhere in the TeaTV settings where I can change the default player, otherwise.
When you choose external player it Plays with mx player I just tried it on my sheild to make sure. I see it doesn’t actually say mx player but external is mx . So as stated above go in tea tv settings down to choose default Play choose external player . Back out I like to get out of tea tv restart after changing settings and play a link and choose play with external player it doesn’t say mx but external is mx . Hope that helps stream on enjoy
