I downloaded cinema app and chose max player that was down loaded on the TP Rapid installer. Not getting any sound. I can run vcu player and it does play
It has to be a setting, seems MX does this quite a bit.
What makes me nervous is that you mentioned TP rapid app installer. This isnt around anymore…maybe you meant you have had it on your stick for a while…hopefully. Why not use the built in Cinema player, or if you must use an external, why not VLC?
Hi I have the same problem you have I got Cinema and I got a mix from Troy point so if you fixed yours can you give me any information on it I would appreciate that
