MX Player drops network path to my NAS USB SanDisk 500 GB
NAS is a USB stick on a ASUS RT-AX3000.
Not a real NAS box.
It drops and will not re-estatblish the path even after reboot or force stop,
My PC’s see it fine and can connect.
It cannot sustain the local network path. “Disabled”
I uninstalled. reinstall via TP toolbox. No luck. This time it would not respond to ONN 4K mouse control. Did it again and used update.
No luck.
Rebooted box (pulled power). No luck.
Stumped.
Any other .ts players out there from reputable sources?
T.IA.
–Biz
Installed latest version from Google. No help.
Justa thought…Do you have xplore installed by chance?
Yes
It sees the USB and can read/write.
have you tried setting up the lan portion of xplore? Click on lan, scan for servers and if it finds the device, set it up.
Yes done that.
xplore works.
I found an older version of MX Player.
Uninstalled newer version.
Install old version.
Did not let it update…and
SHAZZAAM!!!
It works fine now.
