MX player caching 400mb per movie
Hi , I have recently downloaded a recent version of mx player and after watching a movie it has filled up with 400 mb of cache , has anyone any idea if it is meant to do this ,or is it just the one I have downloaded, on a 4k max fire stick, thanks.
I`ve not noticed that in particular but I also always close background processes and clear the cache in everything. At times, I will also just go through my apps and find even though not used, or seemingly not used, they fill up some. I clean all cache.
Hi , yeah I always close things I’m not using and always clear cache in everything ( prob a bit OCD) . I downloaded mx from a site in unlinked, just never came across this before, will look for another mx link that doesn’t cache 400mb a movie, thanks for reply.
The only issue I can find for MX Player Pro is a tendency for it to download a large font cache for subtitles.
Yes, 400 Mb seems rather excessive. Another app from somewhere might be worth a try
