Hi all, my apologies if this has been previously addressed.
I have Cinema HD on 2 firesricks. One plays movie trailers in Silk. The other plays them in the YouTube app. The Silk browser is not a good experience.
Is there a way for me to direct the trailers to play in the YouTube app?
It should give you a choice. If not, then most likely when given the choice you chose the “ALWAYS” button instead of the “ONLY ONE TIME” button.
The only way I have found to correct that is to delete data or uninstall and re-install. Either way any addon (Real-Debrid, Trakt, etc), favorites, watch list, and history will be deleted.
Before you uninstall. Look in the details of the app in your app manager area and find the out what is the exact version you have and then find and download that version again.
