Hello - is there a way to move your favorites from one app to another so you don’t have to start all over in a new app?
Much thanks
Much thanks
Not really, unless you use trakt, if one app uses it and so does another you can have it transferred the way.
What apps are you referring to…movie/tv series apps? I have backed up my watchlist in TeaTV & sent it over to my other device via (Send Files to TV or Send Anywhere) & then done a restore from the file I sent it to…also did it with favorites in Film+…but the restore couldn’t find it & I had to move the backup file around in my file mngr…& that was a pain. Then, I finally took @Miki 's advice & set up Stremio (easily) on my computer & voila…because it’s on the cloud, every other device where I set up Stremio was identical to my computer setup…& the torrent links have been working flawlessly so far.
Or…like Dracoo stated…Trakt is actually designed for multiple apps & can be activated in most of the popular app Settings. But I’d go with Stremio…it’s
Hello - like movie my favorites from
Cinema to another app. I’m new to this and I don’t know how to move files like this.
Any help would be appreciated m
Much thanks
I’m using a firestick btw
You need to use trakt to do this.
No…you can’t move favorites from one app to a different app…my method is for the same app on different devices. For what you want to do, as Dracoo said, you need Trakt.
