I reached out to my provider and followed their instructions. No luck. I just received a notification from them that there is a system wide issue on their end and they are working on it and give then time.
Hi mate, just to say - I’m having the same issue. I suspect same provider. BBC One only. Very odd.
I’ve raised an issue with the provider but doubt I’ll hear back. Did you have any luck in the end?
Same result. My IPTVsaid itwas on their end andnever hesrd back.l
In all honesty, it could be the provider of that list you’re using which is why the logos are not working. I could be wrong also though
