Missing dependency on kodi
When trying to install Magic Dragon or Exodus Redux on Kodi 18.9, I keep getting a message
The dependency xbmc.python 3.0.0 could not be satisfied.
most likely find your answer here>>> The dependency on xbmc.python version 3.0.0 could not be satisfied. · Issue #498 · Sandmann79/xbmc · GitHub
@TXRon
Good link.
@DenL
Be sure to check out my kodi guide because the troy team has 18.9 and matrix viable options on each guide if they are available. Most stuff has been upgraded to matrix so you can use 19.3 on most things.
That code is a combatablity issue.
