It seems nothing I download goes into either my internal or external storage. I’m trying to see where there is a place in the settings that allows me that option. Both my storage shows up. Even though I download a picture it seems to go no where. I’m using a MeCool KM7 so plenty of space and a 32gb external USB with nothing on it. Thanks
Solved I think for now
How did you solve it? Inquiring minds want to know.
The problem might have been I wasn’t registered with WallPaper Cave. After I did it seemed to work. Not sure if this was it but now I can do what I wanted. Wall papers now download and go to the proper file now. Call me crazy
