Hi I have a problem with my mecool km6 it keeps logging out when watching live tv. Is there a way to reset the unit to default settings as I believe that a setting is not correct. Any help will be appreciate.
I’m a little confused what you mean by “logging out”. You said you were watching live TV, does it log out of the IPTV app, VPN, etc?
I am using a website in Thailand name fwiptv to watch UK tv channels. Every time I select a channel it just return’s to the home page. This also happens with live net. Just need to know how to set mecool km6 to default settings. Thank you.
I cant find a “defaul settings” button in the KM6’s menus. I would factory reset it and reload everything to see if that helps.
Ok thank you, will factory reset.
