Any tips tricks or apps I need to keep it in good working order
No nothing other than thr ordinary usual stuff.
That review has help points. My advice would be to start removing bloatware or any unneeded pre-installed apps to clean space, followed by a cleaning app like task killer and SD maid. Turn on the function install from unknown sources then use troypoints app and installer.
Should be good to go! I hope you enjoy it the box!
Thought Task Killer was for Fire OS and not for Android TV 10 OS.
Was using it as a example, probably a bad one. My point is to keep those apps clean and run sd maid pro on your device. There is more utility apps in there to help with this.
The rapid app installer will have everything you need to maintain the box.
