I have several MEECOOL devices and this is my second KD3, had problem with the power adaptor and had to replace the first one.
Trying to setup a new one and when it gets to setup it is flashing the setup pages, but no time to enter anything. I have replaced the power supply and that makes no difference. I have set the remote per instructions.
Anyone having this problem with a new stick? Any suggestions?
Thanks for any suggestions.
John
Hey @jflinternet If your remote works & you can get to any settings in the UI…I’d try a factory reset & start the process all over…with a proven power cable/adapter/hdmi cable…pull batteries out of remote to clear its memory also.
Power plugged into wall socket…
Thanks, pangaeatech, I miss a basic check. I replaced the power plug, but did not test the remaining wires. Tested all the wires and found it was the short extension they supply to connect to the TV that was bad, replaced that and all is good.
Thanks for the help
John
Excellent…glad you figured it out.
