If there are any tutorials or any helpful information and how to make an upload a Kodi build I’m using Kodi 20 rc2 with Windows 10 and I’d like to make an upload of build it would like some info for it thank you
There’s 3 parts here. How to make a build, how to save it, and how to upload it.
As for how to make it, that answer is way too long and totally up to you what you want to do with it. It’s really just a custom skin, widgets, icons, fonts, etc. with whatever addons you want to use. There are endless possibilities.
In order to save a build you’ll need to use one of the wizards from a repository. But be careful. You need to remove all of your personal information. Any Real Debrid, Trakt, or other account info. Sometimes even if you unlink your accounts there can be traces of it in the code. That’s why you also need to use the other tools in the wizard to clear all that out before saving.
As for how to upload it, that’s just as complicated. You’ll need to figure out how to create your own repository and then get the word out if you want other people to be able to find it.
I have windows 11, and Kodi v20. doesn’t work properly, i would recommend 19.4.
Thank you this is actually been very helpful! happy streaming
