On Mad Titan Sports I get a “Youv’e been banned contact your provider” Whats with this?
Try a VPN and switch locations. I get that often on the free IPTV playlists in TiViMate.
You’re probably seeing this when you select one of the iptv “tails” links. It just means that particular link is not available. Just use one of the others. It’s all hit or miss.
I will try a different location out of California because I’m using San Jose and wanting the PAC12 games. Thanks good idea
I will try a different location out of California because I’m using San Jose and wanting the PAC12 games. Thanks good ida
Moved to Las Vegas and it works just fine now Thanks
