I;m not so much worried about the cache as I am about the storage and data. Not a big deal, but I’ll keep an eye on it. Don’t think this app was made to be on Nvidias
Hmmm. I never bothered looking at storage. Mine is 159 and this max is approaching 2 yrs old.
Thanks all of you Troypointers for some great info. It gives me options to try and see what works for me.!
Geeham
I didn’t know you could put SDMaid on a schedule.
I just set a schedule for System Cleaner. What other ones should I set like maybe App Cleaner
I think on SD Maid Pro you can run it on a schedule.
Yep, at least the pro version you can. Been so long since I used the free version I dont remember if its there. But once all setup correctly you can. SDmaid pretty much needs all permissions so once all setup I go back in and re-check everything and eventually scheduler is opened up and defaults to 3 days. I set to clean all. Helps alot on my ugoos because I golf on it and the last thing you want is a sluggish box.
I didn’t either until Ron said something about it. I set mine up for weekly. The option was available the whole time, I could kick myself for not seeing it lol. Great call @txron!
Lots of people set sdmaid up real quick, set it and forget it but not right. It takes time to get it right. I know I did and started wondering why this or that was not cleaned…hmm …permissions permissions permissions
